B and M Shift kit???
Old Jan 19, 2007 | 07:20 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
Anyone using a B and M shift kit?? If so pros'??? cons??? any tips for me?? (700R4) thanks, Tom
Old Jan 20, 2007 | 12:19 AM
TheScaryOne's Avatar
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
First off, get the TransGo, I got the B&M, and I regret it. It kinda tricks your tranny into shifting harder. Not really that great of a setup. But if you're gonna do what I did (work with whatcha got) then here is the following advice.
Get more tranny fluid than the book says. It lies. Get their "advanced" kit, or whatever. Instead of $55, it's $70, and comes with a new filter, saving you the $20 filter and gasket kit. Have a lot of parts cleaner. If you can, do it in the air, if not, try not to do it over a parking lot. Concrete is preferable. Take apart is easy. The valve body is HEAVY. Check the pan for any debris, at all. If there's anything down there, more than just a little around the magnet, look at a rebuild, and if you do a rebuild yourself (or find a super cool shop) get a pro built rebuild kit. Forged hardparts for $482 or so.
After you get the old filter out, cut it apart. And make sure you got the o-ring out. Check for excessive debris. When it says to file down the little posts, more is better than less. Buy a small tank of solvent to clean all of your parts with before reinsertion, cheapest I saw was at checker for $25. DO NOT LOSE THE LITTLE *****! And the hardest part is reinstalling the valve body and hooking the manual valve back up with the linkage from your throttle. Everything else is cake, well, except the boost valve. And even that's not that hard. If you have any questions, just ask.
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
