Manual Transmission options
Old Jan 23, 2007 | 03:51 PM
Electron_Blue's Avatar
Car: 83 Camaro
Transmission: th350
Ive been thinking about tearing back into my camaro and redoing the drivetrain. I was just wondering what other transmission options are out there besides the t5 and t56. I would like a manual but ive also been looking at probuilt 700r4's as another alternative to my current th350. My only requirement is that it has an overdrive gear and has matching splines/bellhousing. Lemme know if theres anything out there i should look for. Thanks guys
Old Jan 23, 2007 | 04:14 PM
87LS's Avatar
Car: 87 Camaro LS
Engine: LG4
Transmission: T-5 World Class
Axle/Gears: 3.08 Open baby!!
Your trans's mentioned are good ones
Also look into a TKO 5 speed, and if you have a computer run engine
the 4L60E and the 4L80E are awesome as well
Old Jan 26, 2007 | 01:15 AM
Pat Hall's Avatar
The Tremec TKO's are good choice. They have an overdriven 5th gear, and they offer ones with a 26 spline input shaft, so they'll work with a stock T5 bellhousing and clutch setup. They also use a mechanical speedo, so there's no need for an expensive converter box like you have to do with the T56. Plus they're leagues stronger than the factory T5 trans.
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
jhawkeye
May 25, 2022 06:33 PM
Vintageracer
Jan 10, 2020 05:33 PM
bjpotter
Jan 22, 2019 12:27 PM
topher107@
Aug 28, 2015 10:47 AM
