quick plea for help
Car: 87 Iroc-Z
Engine: 5.7 350 TPI
Transmission: stage2 700r4
Axle/Gears: 2.73 for now
quick plea for help
i had wierd tuck tuck tuck sound pretty loud coming from under my car . Transmission would not engage into any gear. When i do put it into drive the car just revs and the tuck sound gets louder. I removed the inspection cover for the tranny and rotated the torque converter- the bolts holding it to the flexplate are all intact, and both turn together.
I started my car and went down there, and it sounds like its coming from inside the torque converter. Is this possible?
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
is the shiftrer linkage attached to the trans pan? are all the bolts in it? do you have any tranny fluid?
Car: 87 Iroc-Z
Engine: 5.7 350 TPI
shifter linkage is on the pan - all the bolts are in, and yes there is oil in the pan. I can hear the sound coming from inside torque converter...is that possible??? are there parts that break inside??
3.8TransAM
Sep 27, 2015 08:37 PM
