Car lurches forward on startup,causes?
Old Jan 26, 2007 | 08:15 AM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
Hey everybody,I have a question.Sometimes when i start my car up in the morning it kind of lurches forward a bit,almost like someone bumping into the car from the rear.does anybody know why it would do this?
Old Feb 21, 2007 | 11:07 AM
Michelob's Avatar
Car: 87 L98 TPI
Engine: ZZ-4 heads, LT1 cam, AUJN Prom
my 87 does the same lurch at startup.... i haven't verified it but may be from mixing in a couple quarts of thicker type F fluid. mine is also prone to stalling the motor on the shift from park to drive at warm idle .
Old Feb 23, 2007 | 07:44 PM
vbMike's Avatar
Car: 1987 Camaro IROC-Z28
Engine: TPI 350ci L98
Transmission: T56 - Hurst Shifter
Axle/Gears: BW - 3.70
I think this is common with automatics. My 87 Camaro and 2000 Monte both do this as well as other vehicles I've driven. I'm not sure of the exact cause.
Old Feb 23, 2007 | 10:54 PM
IROC-You's Avatar
Car: 87 IROC-Z28
Engine: 414ci Twin Turbo
Axle/Gears: Ford 9"
mine doesnt lurch on startup, but if in park and i rev the engine is will SLIGHTLY roll forward until it hits a gear in the parking pawl.
If its in neutral i can get it to roll pretty far lol.
Old Feb 24, 2007 | 03:58 PM
vbMike's Avatar
Yea that's basically what mine does. If the parking pin is not fully enguaged it will lurch forward slightly when I start it until it catches. It only seems to do this when the engine/tranny is cold. Maybe cuz the tranny fluid is thicker.
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
mizz0313
Aug 12, 2015 06:45 AM
gwade12
Aug 8, 2015 08:17 AM
