What did I break?
Old Jan 27, 2007 | 04:57 PM
no1kicker's Avatar
Car: 1991 Trans Am
Engine: 5.3L
Transmission: auto
What did I break?
1991 700r4 behind a 305 tpi, 95k on it. It doesn't want to shift out of 2nd. 1st gear seems fine. It will shift into 2nd, but leave it at light throttle and it jumps into neutral. You have to rev it to above 3k and then it shifts back into 2nd.
Time for a new tranny?
Old Jan 28, 2007 | 05:32 PM
S105.7's Avatar
Car: '87 S10 Blazer & '91 RS
Engine: L98 & L03
Transmission: 700R4 & T5
Axle/Gears: 10 Bolt/3.73/3.42
that would be the clutch packs, i think. the same thing happened to mine this past summer. it needed an entire rebuild.
Old Jan 28, 2007 | 05:56 PM
tpi355's Avatar
Car: 86' IROC-Z/03' Silverado Z-71
Engine: 355TPI/ 5.3 Ltr.
Transmission: 700R-4/ 4L65E
Axle/Gears: 7.5 in.-3.73 POSI
reply
There is a band inside that runs off of a servo, it slows down the drum and in turn makes the first to second gear shift, sounds like either your band is worn out or the drum it rides on is wore out or broken, either way your gonna have to pull the tranny to fix it. If its not that u have valves sticking in your valve body, but I don't think that would make it shift into nuetral, sounds like internal problems, like clutch packs or one of the shift bands and or drums
UltRoadWarrior9
Apr 28, 2020 10:39 PM
apie2546
Oct 16, 2016 02:24 PM
ZekeThorpe
Theoretical and Street Racing
35
Oct 7, 2015 07:30 PM
sjorgens
Oct 1, 2015 07:54 PM
mfp189
Sep 27, 2015 09:25 AM
