lock up switch installation
Old Feb 2, 2007 | 12:17 PM
roughskinjrz's Avatar
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
i had brought my car to get a shift kit, and 3000 stall to get installed in my 700r4. he said he wired a lock up inside the transmission i just need to set up the switch? now he gave me a connector, which was broke, that goes on the side of the transmission and said just go pick up a new one and run the wire to the on/off switch and other to ground. Then ground the switch, and also stick one wire in the fuse box (three wires coming from the switch)
is this all that needs to be done to get my lock-up working on my transmission?
Old Feb 2, 2007 | 01:12 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Depends what he did inside the transmission, but it could be that simple.
Old Feb 3, 2007 | 07:06 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
any certain questions i should ask?
Old Feb 3, 2007 | 07:56 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
See if he can give you a wiring diagram.
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
I'llrocya
Feb 2, 2016 11:43 PM
