th350 short tail
Old Feb 4, 2007 | 07:27 AM
dirt_kx's Avatar
th350 short tail
if i put a th350 with the short tail shaft in my 85 z28 what do i have to do to make it work thanks for your help
Old Feb 4, 2007 | 07:50 AM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
get a longer driveshaft and move the cross-member forward. plus i think the torque arm might be an issue but i'm not sure. if you have one being built for you, have them put in the longer output shaft and tail housing(9 inch tail) and save yourself the trouble of the driveshaft and torque arm hassle. with te longer tail and 9 inch housing, you should be able to reuse your 700 tail housing.
Old Feb 4, 2007 | 08:19 AM
dirt_kx's Avatar
thanks for the info ive been trying to find a th350 with the long tail shaft
but every junk yard that i called all said that they dont have one but a guy i know has a th350 with the short tail shaft thats been built to handle 600 horse and he has a stall conv for it they both have around 200 miles on them
he wants $250 for them how much do u think it would be to put the longer tail shaft on it and would it be worth the hassle or should i just wait till i find the th350 with the long tail shaft
Old Feb 4, 2007 | 08:23 AM
87zjeff's Avatar
to put the longer output shaft in it would require it to be taken apart. if your local junkyard has any '82 or '83 camaros/firebirds, those years had the longer torque arm, driveshaft, and the proper crossmember that you need to make the short one work.
Old Feb 4, 2007 | 08:57 AM
dirt_kx's Avatar
Old Feb 7, 2007 | 08:10 PM
whitez406's Avatar
If you want to use the short tail get a b&m mount kit its like $100.00. This solves are the torque arm and mount issues. In the instructions it tells you to use a driveshaft from an 82 camaro with a th200, which are kinda hard to find. I had one made and i have one th200 driveshaft. If you need a driveshaft let me know.
3rdgenparts
May 21, 2016 11:50 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
