9 inch tail shaft?
Old Feb 4, 2007 | 09:51 PM
dirt_kx's Avatar
9 inch tail shaft?
i just bought a th350 the owner said it was the one with the short tail shaft
but when i got home and measured it from where the four bolts hold the tail shaft in place to the end of the tranny it measured 9 1/4 inches so would that make it the long tail or am i measering it wrong thanks for any help
Old Feb 6, 2007 | 11:15 PM
tommy z-28's Avatar
Car: 1985 z-28
Engine: 350ci
Transmission: 700-r4
Been about a year since i installed mine, but yeah that would be what 82-92 ppl call a long tailshaft. It will fit iwth the stock 700r4 driveshaft. There hsould also be a 6" tailshaft version and a longer one (according to my trans shop).
Old Feb 7, 2007 | 12:04 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
sounds like the long tailshaft which would fit in the stock 700R4 driveshaft
Old Feb 7, 2007 | 12:14 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Your good, be sure to remember that the 1st gear ratio is around 2.5, the 700r is like 2.97 or so, i have seen a loss in 60 foot times(1.8 up to 2.0) so if it does not feel as good launching you will know why, unless you use a stall...
Old Feb 7, 2007 | 01:05 PM
xpndbl3's Avatar
Car: 1984 Z28
700r is 3.06
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
3rdgenparts
May 21, 2016 11:50 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
gord327
Sep 29, 2015 10:18 PM
6998poncho
Sep 25, 2015 02:56 PM
