Speed sensor help
Old Feb 5, 2007 | 02:18 PM
1badrocZ's Avatar
Car: 1985 IrocZ
Engine: Carbed 383
Transmission: Tremec T-56
Speed sensor help
im installing a tremec t-56 and in my 85 camaro and im not sure what i need to buy to hook up the cable to the transmission. I believe it uses what the t-5 does. I probably need some kind of housing and a speedo gear. The gear inside the transmission is blue and it looked like it was a 6 tooth. What tooth gear do i need to match up with the 3.42 rear end and where do you buy the housing and gear from?
Old Feb 5, 2007 | 02:53 PM
Comp788's Avatar
Car: 1982 Z28 & 1967 RR/SS 396
Engine: ZZ383 & 375hp 396
Transmission: T56 & factory TH400
Axle/Gears: 9" ford & 12 bolt 4.10
One of the companies that advertizes on the board will have everything that you need. They can also help you out with the correct great to match your rear end gears. You will need to tell him your tire size too. That will effect the spedo as well.
Here is the link: http://www.transmissioncenter.net/sp...____va.htm#400
Old Feb 5, 2007 | 05:08 PM
1badrocZ's Avatar
Car: 1985 IrocZ
Engine: Carbed 383
sweet! got my parts ordered thanks for the help.
Eric2ndGen
Nov 5, 2015 01:51 PM
angel2794
Sep 8, 2015 06:22 PM
IROCtometal
Sep 2, 2015 02:01 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
