trans swap ?
Car: 91 ta
trans swap ?
just swapped from an auto in my 91 ta to a t-5. the t-5 has a mechanical speedo out put and my ta is electronic, anybody have a part number for a vss that will go into a t-5 or a cable driven pulse generater to make my speed o work?
Car: 1979 malibu wagon
Engine: 305 tpi
Axle/Gears: 8.5 3.42
I need what you have!
I have a T5 from an 87 Firebird that has the electronic VSS on the trans. I need the mechanical unit. Would you like to swap?
I have a VSS from a 92 RS Camaro that had a T5. This should be the correct one for your 91. I've had both styles, and this is the smaller one. The electrical plug is also different from the older ones. If you're interested, I'll let it go for $35 shipped. Let me know, Pat.
1992 Trans Am
Aug 8, 2015 08:16 PM
