LT1 Rear in 3rd Gen?
Old Feb 10, 2007 | 11:27 AM
A Seven X's Avatar
Car: 93 z28
Engine: 350 lt1
Transmission: 4l60
Axle/Gears: ??????
would a rear end from a 94 Lt1 camaro bolt right up with no mods?? or is it going to never happen for me? im getting a good deal on this rear end w/3.73's prof. installed...i need to know asap..
*FYI* my rear end housing is CRACKEd... and posi unit is bad havent priced a posi unit but i bet its alot mre than what im getting this rear end for..
thanks
Old Feb 10, 2007 | 11:53 AM
Z28guy83's Avatar
Car: 83 Z28
Engine: 400sb
yeah it will fit its 2 inches wider than a stock third gen rear and as a plus you can run 4th gen wheels on the rear with no spacers (would need the spacers for the front) just search 4th gen rear there is alot of pics on here
Old Feb 10, 2007 | 12:02 PM
deadtrend1's Avatar
also, you would be getting disc rear brakes with the LT1 rear, so you would want the cables if you got drum rear now....
Old Feb 10, 2007 | 10:15 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
You also want the entire brake lines on the rear end, but there's no promise they will bolt up to your existing '86 brake lines.
Old Feb 10, 2007 | 10:55 PM
A Seven X's Avatar
Car: 93 z28
Engine: 350 lt1
Transmission: 4l60
Axle/Gears: ??????
cool thanks guys i appreciate the responses.. ill let you guys know whati decide to do..
midge54
Dec 27, 2019 04:14 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
sreZ28
Aug 14, 2015 07:48 PM
Eagle223usa
Brakes
Aug 14, 2015 09:24 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
