posi rear
Old Feb 14, 2007 | 08:02 PM
cway's Avatar
posi rear
Hi, I have a 1991 Firebird with a 10 bolt non posi
drum brake rear in it. I want to know if I could put a
9 bolt disc brake posi rear (from a 1987 Z28)in my car and use the
backing plates and the drum brakes from my 10 bolt non
posi rear in the 9 bolt posi rear? Thanks
Old Feb 14, 2007 | 08:12 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
1st let me say welcome to the boards. Why would you want to keep your drum brakes????? Do a search and you'll find a ton of info on the swap
Old Feb 17, 2007 | 09:09 AM
cway's Avatar
The reason that I want to do this is because the guy that has the 9 bolt posi rear for sale is going to keep the backing plates,rotors,brakes,porportioning valve, and the e-brake cables for another rear. The car that this rear is out of is in great shape and only has 76,000 miles on it. He is putting a new rear in his car since he is putting a 383 stroker in it. I thought that if i could use my backing plates and drum brakes that it would be alot cheaper and easier for my car.
Old Feb 17, 2007 | 01:21 PM
dirtye30's Avatar
Car: 89rs
Engine: 350 tbi
Transmission: stock
why dont you just swap the carrier and gears>?
Old Feb 17, 2007 | 04:43 PM
krisb410's Avatar
I don't think they are interchangeable
9 bolts have a different size ring gear then 10 bolts
hectre13
Dec 11, 2023 08:14 AM
Reddeath210
Oct 6, 2015 08:20 AM
tcflint
Exterior Parts for Sale
Aug 26, 2015 05:45 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
AkDrifted
Aug 17, 2015 07:45 PM
