Ok guys heres a few questions i have, what bell i know i will need the lt1 bell housing, will i be able to use the ls1 t-56, will anything need to be modified for it to be able to work with hooker long tubes and a mufflex ory? Should i use lt1 or ls1 pedals, i know that i can use the thirdgen manual console or i can put a forth gen one in there, what do i need to do as far as wiring, i have an auto now. Now what do i need to do as far as hydrolics, flywheel, and clutch? Also what do i need to do get my umi torque arm to mount up, and as far as a cross member i believe that spohn makes one. And will my powermaster mini starter work wit the lt1 bell housing. thanks in advance and let me know if any of my questions are not clear enough.
Run a search on this. It's been covered over and over again. I myself have written out explanations of the whole swap 3 or 4 times.
