3.23 gears ok???
Old Feb 17, 2007 | 12:50 AM
dirtye30's Avatar
Car: 89rs
Engine: 350 tbi
Transmission: stock
3.23 gears ok???
how would my lightly modded 89 camaro react to 3.23 gears and a posi?? yes no? the only mods i have are performer intake an 600cfm carb, HEI dizzy, mallory FPR, lowered suspension with air adjustables, 700r4 lockup, flowtech shorties and a 3inch magnaflow exhaust and i think thats it. i know uch of that doesnt make a difference just stating that its there... TIA
Old Feb 17, 2007 | 01:13 AM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
well if it came stock w/ the infamous 2.73s it should be a nice little jump in torque multiplication at the rear wheels...plus of course the posi. should wake it up nicely...
i get my car back tomorrow from the shop, dropped it off monday to have my eaton posi, 3.42s, and superior axles dropped in. can't wait to break it in and let her rip!
2.73s suck.
Old Feb 17, 2007 | 01:44 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
has 2.73's now?
I think that'd help a bit. With the overdrive you can go higher, 3.42 is what i'd recommend, but if you have the 3.23's or something, i'd use 'em.
Old Feb 18, 2007 | 10:25 AM
Pat Hall's Avatar
I also have an 89 RS that came stock with the 2.73's. I'm running 3.23's in it now, and it's a major improvement over the pathetic 2.73 ratio! I've also run 3.42's in it. There's not a huge difference between 3.23/3.42, but both of those ratios make it actually drive more like a sports car instead of feeling like grandma's Delta 98.
Old Feb 19, 2007 | 11:39 AM
marballfire's Avatar
Car: 88 Camaro SC
Axle/Gears: 3.42 POSI
I got 3.08s now and i'm lookin to change them with 3.73s. How much do you think that'll run me with parts and labor. Just as a ballpark figure.
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
Numbah-1
Sep 12, 2015 08:57 PM
Stroopwafel
Sep 11, 2015 06:38 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
