Clutch won't disengage!!! help me out!!!
Car: 99 Mystic Green Trans am
Engine: LS1: Heads, MS4 cam, bolt'ons
Transmission: Fully built T-56 w/Spec3 & Pro 5.0
I have a 86 one piece rear main seal 305 hooked up to a t-56 trans from a 96 Camaro. I have a 1" bore Willwood clutch master and stock slave. My clutch is a spec stage 1.
The clutch pedal goes only as far as pressuring the system before stopping dead. I don't want to force it too much because it is a $80 clutch master and i don't want to brake it. I had a fluke 1 time where it went to the floor but after it came back up it would only go 2" in again.
I can put it in gear when off and start it and it will move so it is set right.
The only thing I can think of is that the flywheel I paid $120 for and spent $60 getting it resurfest before finding out it was a little warped. I could rock it back and forth on flat ground about 1/2-1 mm, I put it in anyway. I am wondering if it is making enough of a difference in tilt that the throwout bearing is being pinched on the forks so it won't disengage. But I was thinking that the plate would mash together and it wouldn't matter.
Anyone have thoughts on the matter I will be using my friends lift tomorrow hopefully to take it out for a look-see.
I have found these flywheels for my app. for $100 brand new
are they any good?
http://cgi.ebay.com/ebaymotors/Chevy...mZ230093486101
Thanks in advanced, JR
P.S. One thing that really drive me crazy is anywhere is go, even a dealership, and I say, "I'm looking for a flywheel for a V8 Camaro 93-97" and they go automatic or manual. I really want to beat the living crap out of people. A flywheel is for a manual a FLEX-PLATE! is for a automatic. It has a different name for a reason, GOD!!!! I had to go though this at lest 20 time when I was looking for this POS flywheel,
it gets annoying especially when your talking to supposed “car” people.
Of course maybe I'm expecting to much from people again
are they any good?
Car: 1987 pontiac firebird formula ws6
Engine: chevy 400 cubic inch V8
Transmission: turbo 350
clutch in backwards......happened to my buddy, it was always engaged, took the tranny off looked and instantly felt dumb
Yup i took it out yesterday, after a got my motor running
, and I saw my error. And your right you do feel instantly dumb after you realize what you did
. I don't feel to bad though i installed the whole thing by myself on a wet floor and bad light so it was probable that something like this would happen.
I got my friend to help me hold the tranny up this time
I will be burnning rubber in exactly 1 hour
WOOOOOT!!!
moving on to suspension now
money money money
JR
. I don't feel to bad though i installed the whole thing by myself on a wet floor and bad light so it was probable that something like this would happen.I got my friend to help me hold the tranny up this time
.I will be burnning rubber in exactly 1 hour
WOOOOOT!!!moving on to suspension now
money money moneyJR
Drone358
Dec 10, 2015 08:16 PM
Night rider327
Sep 2, 2015 04:17 AM
