Transmission Governor?
Old Feb 25, 2007 | 12:33 PM
Crusin' 1980's's Avatar
Car: 1988 SC Camaro
Engine: 305 TBI
Transmission: 700-R4
I was just reading a post about installing this in addition to the transgo shift kit, but what does the governor do?...is it the same as the valve for WOT shifts in 4th gear? Perhaps someone can clarify that point, Thanks.
Old Feb 25, 2007 | 12:47 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The governor controls shift points for all gears.
Old Feb 25, 2007 | 01:11 PM
Car: 1988 SC Camaro
Engine: 305 TBI
Alright, so does installing the 'better' governor delay the shift points for better acceleration?
Old Feb 25, 2007 | 01:16 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
There isn't a "better" governor. You can vary the weights and springs on it to adjust the shift points, though.
Old Feb 25, 2007 | 07:55 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
if you grind some weight off it then it will hold gears longer
or so i have read
i tried it once but i dont remember the result or the vehicle i believe it was in one of the caprices i had
forgot now., too many vehicles ago
good luck
Old Feb 25, 2007 | 07:59 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I can tell you that a governor used with the 2.8 TBI in the S-series trucks and 3.73 gears, shifted right at 5,500. I have one in the Van as well as my S15 Jimmy. They both shift right at 5,500, with the untouched governors. OD by 45 mph in both.
http://youtube.com/watch?v=koWaPeAu3hg
Old Feb 26, 2007 | 12:40 AM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
so if the governor controls the WOT shift points, does it also control light throttle shift points? i can not get my tranny to shift before 2 grand at light throttle w/o pulling the tv cable out about 5 clicks.
just curious.
Hotrodboba400
Dec 10, 2019 07:07 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
TX-SleeperC5
Sep 24, 2015 03:13 PM
HikoriYami
Sep 21, 2015 07:11 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
