84 trans am rear in an 89 camaro?
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
well you have to swap axle shafts too since 89 are 28 spline and 84 are 26
but yes you can do it, as long as both are the same axle model,
7.5"
or 9 bolt B/G
or dana 44
but you better darn well know how to set up bearing preloads and have the special tools to check backlash and preload and such or it will be a disaster
youre alot better off/safer to swap entire axle assembly
good luck
7.5"
or 9 bolt B/G
or dana 44
good luck
1992 Trans Am
May 10, 2023 07:19 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
3rdgenparts
Aug 6, 2015 09:03 AM
