Smacking sound under car
Old Feb 28, 2007 | 04:00 PM
townsendz28's Avatar
so yeah, i have an 84 z-28 with a couple edelbrock parts under the hood. my problem is, i have a sound coming from under the car that sounds like a smacking metal to metal to the body of the car. i cannot figure out where it is coming from or what it could possibly be. Tranny mount looks ok, no play in u joints, etc. at slow speeds it seems to make the rear of the car bump up and down a little bit. btw, the axles are straight and rims are fine. Has anyone else had this problem? help me please
Old Feb 28, 2007 | 06:25 PM
kaptinkafeen's Avatar
Have you checked the trq arm mount?
-Andrew
Old Feb 28, 2007 | 07:09 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Put the car up on jack stands or take it to a shop where you can put it up on a lift to inspect the underside real closely. You may find more than one thing contributing to the sounds that you're hearing.
Good luck
Old Feb 28, 2007 | 08:08 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
You should put a jack on the transmission and jack it up while watching the mount. They can tear right at the top or bottom of the mount and appear to be normal while at rest...
Old Feb 28, 2007 | 09:12 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
trans mount...
Been there done that a few times!
Even without jacking up the tranny you can look above the yolk coming out of the tranny and see where it and the driveshaft has smacked into the tunnel!
Old Feb 28, 2007 | 10:25 PM
well come to find that one of the torque arm bolts is loose, ima tighten it up and see what happens
Frozer!!!
Jan 19, 2024 04:55 PM
midias
Aug 22, 2015 01:42 AM
MY87LT
Aug 17, 2015 08:43 AM
mustangman65_79
Aug 8, 2015 12:07 PM
gwade12
Aug 8, 2015 08:17 AM
