which speedo gears???
Old Mar 5, 2007 | 05:26 AM
1988-305-tbi's Avatar
so i'm swapping in a 9 bolt 3.27 posi in place of a 10 bolt 2.73,open rear, i pulled the speedo gears off of the 9 bolt car, there 17/45 gears, but i cant use them cause the donor car had an electric speedo and mine is cable driven, so i'm going to buy a new driven gear, i found a speddo gear calculator on bowtieoverdries, and it says to use a 17/43 setup with my 26" 255/50/16 tires,
so what gears are everyone using with a 3.27 rear and 26" tires
Old Mar 5, 2007 | 06:24 AM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Is the drive gear in your transmission tail housing is the same as the donar? If I remember correctly, you should be able to use the driven gear with your speedo cable housing. The plastic driven gear should swap.
Old Mar 5, 2007 | 06:46 PM
the drie gears are the same style, and teeth, "17" but the driven gear is a different style from cable to electric driven units, so i def need a new driven gear and i'm not sure wich one to get, a gear calculator on 700r4.com
http://www.700r4.com/speedoCalc/speedocalc.shtml
says to use a 17/43, but i've also read post where people use 17/43, 17/44, and 17/45 gears
Old Mar 5, 2007 | 07:09 PM
Wadebryant's Avatar
Sorry for the bad info, I went from cable to electronic. Anyway, try this site, it may help.
http://www.tciauto.com/products/comp...eter_gears.asp
Old Mar 5, 2007 | 08:06 PM
abyliks's Avatar
Car: 02 Mustang
Engine: 3.8 about to be punched out to 4.3
Transmission: 4R70W
Axle/Gears: 3.73 Detroit true trac
will all those work with the VSS on later ones?
Old Mar 6, 2007 | 02:39 AM
Pat Hall's Avatar
http://cgi.ebay.com/ebaymotors/Drive...mZ140003543454 The gears in the link I posted will work with the electric VSS units or the cable style sending unit as long as you have the one that uses a metal shaft with the d-shaped end. They also have them available in 44 and 45 teeth as well. They also have the all plastic, cable style gears if that's what you need.
GTAman
Jul 3, 2024 07:29 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
88rscamar0
Sep 23, 2015 09:08 PM
andy74
Sep 3, 2015 08:41 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
