I forgot what line goes where?..help please
Old Mar 6, 2007 | 09:12 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
I finally got my tranny in and I forgot what lines go where...the 2 fittings on the side of the trans....
The top fitting goes to the top fitting on the radiator? and the bottom goes to the bottom?
what?..which way?
thanks
Old Mar 7, 2007 | 01:37 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
rusually it is top to top and bottom to bottom, but not so for every single tranny model
i forget which are different
but if you knew which port on your trany is the output then that would be the one to connect to the bottom port of the radiator cooler, the fluid has to travel up through the cooler
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
codeysabatini
Nov 10, 2015 04:07 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
codeysabatini
Exterior Parts for Sale
Sep 24, 2015 05:40 PM
codeysabatini
Sep 20, 2015 11:36 AM
