What rear end do i have ??
Old Mar 8, 2007 | 12:34 PM
TON*LOC's Avatar
Car: 1987 firebird trans am
Transmission: 5 speed
Axle/Gears: 4th 10 bolt hope fully it last
ok so this is the 4 10 bolt i've had to put in this f@#$ing car in the past 2 years. i have no idea what the gears are in it but i think it is the 2.73 out of a 87 iroc auto. i got 205/60/16 on the rear. i'm at 1500 rpms at 55 mph. i tried to find an math equation to figure it out but i couldnt find it. am i right in assuming there are the 2.73's
Old Mar 8, 2007 | 02:12 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
pull the diff cover to know for sure, otherwise you will always not be 100%
or get the stamping code off the passenger side axle tube and call your local parts counter chevy dealer and have them decode it real quick if you know the year make model it is from
good luck
Old Mar 8, 2007 | 09:19 PM
TON*LOC's Avatar
i have no clue what it is off i bought it from some dudes back yard. how will i know if i take the rear cover off ?
Old Mar 8, 2007 | 09:44 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
gears are stamped with numbers like 41/11 etc which would be 3.73 for instance. If you keep breaking rear ends on a 305 with a 5 speed you need to drive more conservatively or drop $2500 for a moser 9" like I did.
Old Mar 8, 2007 | 10:21 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
if you chalk mark the pinion yoke and chalk mark the brake drum and turn the drum 10 times around and count how many times the yoke goes around
divide them to get the ratio
such as if the drum goes around 4 times and the pinion went 10 then you have 4.10 ratio
but if its posi then its half that
Old Mar 8, 2007 | 11:36 PM
TON*LOC's Avatar
you know what is crazy it is when i shift from 2-3 and as soon as the wheels stop spinning and grab i get a "CLUNK BOING BREAK" and i give a F@%& !i was going to try to run the BW 9 bolt i hear there way stronger than the 10 bolt.
hectre13
Dec 11, 2023 08:14 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
