OK, This T-5 swap ? has probably been ansewerd a hundred times...
Old Mar 9, 2007 | 01:24 PM
Ogre91's Avatar
Car: 91 Camaro
Engine: LO3
Transmission: T5 (converted from auto)
Axle/Gears: stock RS
I swaped a T-5 into an auto '91 RS and it was a real b*$%# kitty to stab, it is hard to shift and has to be forced into gear. I've been away from manual transmissions for a long time, so what are the most likeley culprits? I thought it must be the clutch alignment, but I pulled it apart and realigned it about 4 times and that didn't fix it.
Old Mar 9, 2007 | 07:03 PM
Rainman's Avatar
Car: 1989 Firebird Formula
Transmission: WC T-5
Axle/Gears: Moser 12 bolt, 3.73 gears
Have you checked the fluid level?
just wonderin. i dont know much about transmissions.
Old Mar 9, 2007 | 07:26 PM
SaintedCorrupt's Avatar
Car: '85 TA
Engine: Carb'd 350, ported 416s
Transmission: retrofitted T5
Axle/Gears: 3.42 7.62" 10-bolt, locker
I'm thinking maybe you put the throwout bearing on wrong. if that's not on right, the clutch won't engage all the way, or at all. Notice the thin metal tangs in the purple circles. are they inside the groove like this or outside?
Attached Thumbnails OK, This T-5 swap ? has probably been ansewerd a hundred times...-throwout.jpg
fonzie85
Exterior Parts for Sale
39
Mar 16, 2016 07:07 AM
midge54
Sep 2, 2015 06:27 PM
Cacike
Aug 27, 2015 05:10 PM
Street Lethal
Aug 13, 2015 08:28 PM
armybyrd
Aug 10, 2015 09:23 PM
