rear end swap
Old Mar 15, 2007 | 10:20 PM
lschweit's Avatar
Car: 91 Firebird RS
Transmission: 700-R4
rear end swap
i have a 91 rs with 2.73's and am thinking about swapping for an 82 trans am rear with 3.73's and posi is this going to bolt right in? They are both drum I am just unsure if I will need brake lines out of the 82 or any of the e-brake assembly.
Old Mar 15, 2007 | 10:25 PM
driver101's Avatar
Car: 91 rs,1 92 rs,92 b4c/1le
Engine: 5.0tbi,5.7 tune port/5.0tpi
Transmission: 5spdx2 and t56
Axle/Gears: 3.08,3.73,3.42
if you swap complet housing should be no problem i avid the whole brake problem by using orginal backing plates
luke
hectre13
Dec 11, 2023 08:14 AM
IroczFan
Oct 6, 2015 10:13 AM
hectre13
Aug 26, 2015 08:17 AM
mizz0313
Aug 12, 2015 06:45 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
