No Downshift at WOT....TV Cable?
Old Mar 17, 2007 | 04:41 PM
88Camaro_04's Avatar
Car: 1988 Chevrolet Camaro
Engine: 5.0L 305c.i. V8
Transmission: TH-700R4 Automatic
Title pretty much says it all, at WOT the Tranny won't downshift. This is on a 305 TBI V8, i'm not sure if the cable is adjusted correctly. Any help that you guys can provide is appreciated.
Old Mar 17, 2007 | 05:08 PM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
The procedure for adjsuting it isn't that hard, so I would rec. that you just do it and see what happens. Does it upshift normally?
Old Mar 17, 2007 | 05:12 PM
It upshifts normally, I just redid the exhaust so maybe i'm just not used to the loss of low end torque. I pulled the Throttle bracket to the WOT Position and pulled the cable out as far as I could. Then slipped the cable back on, thats the only way I know how to do it. I took it out for a real quick test, I think my Tach is off there is no way it hit 7,000rpm before shifting.
Z28/ZR1
Oct 23, 2015 01:04 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
