6 speed swap in a 1986 IROC
Old Mar 21, 2007 | 02:15 PM
chevy014life's Avatar
ok i have a few questons about the swap from and Automatic 700R4 to the T56 i found a 86 firebird with pedals and some other misc.parts i know i need the trans, bell housing, master and slave, clutch etc. but what im wondering about is the computer is set up for an automatic, will that be a problem? also that year trans should i look for that requires the least modifications.and i was wondering that i do to hook up the spedometer becasue someone told me the T56 have an electric type hook up? anything i should look out for? problems, suggestions?
Old Mar 27, 2007 | 09:57 AM
Re: 6 speed swap in a 1986 IROC
does anyone know what to do about the computer? or the spedometer?
becasue the computer is set up for an auto now, what will happen when the standard is in.. also the computer needs to read the VSS signal, if i use the abbott cable x i can use my stock guage so that will work but how do i make shure the speedometer is correct for the gear ratio because there will no longer be a spedometer gear in the trans to change for a different gear ratio?
Old Mar 27, 2007 | 10:07 AM
Since you have a Camaro, in that year it uses a cable speedo. The VSS is on the back of the instrument cluster.
Check the thread in the FAQ board titled something like "T-56 questions you haven't asked yet", and do a search on this board. This question has been asked and answered dozens of times. No point in redundantly answering a redundant question.
Steven 86IROC-Z
May 24, 2026 04:52 AM
InfinityShade
Aug 22, 2015 08:00 PM
StevenB L98/LS1
Aug 22, 2015 09:03 AM
kyleb24
Aug 15, 2015 08:24 AM
mustangman65_79
Aug 11, 2015 03:17 PM
