th350 or 400?
Old Mar 29, 2007 | 10:26 AM
Batass's Avatar
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
th350 or 400?
Im building an estimated 650hp 383, and I was planning on a th400, but my engine builder would rather use a 350, says they hold up and the 400s take more power to turn. This car will be beat so I'd like something sturdy. What do you guys think? Manual valve body, reverse.
Old Mar 29, 2007 | 10:31 AM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
Re: th350 or 400?
Your builder is right about the TH400 using more horsepower to turn.The TH 350 can be easily built to handle that amount of horsepower and it's noticablly lighter and smaller than the TH400.Even the 700R4 can be built to handle that and you have overdrive for highway use.
Old Mar 29, 2007 | 01:51 PM
rjt76's Avatar
Car: 1986 iroc z
Engine: vortec 383
Transmission: th350
Axle/Gears: 3.73 moser 12 bolt true trac
Re: th350 or 400?
a friend of mind has a 70 chevelle and drags steady with it. he has around 700hp and has trashed a 400 tranny twice. Build what you want to but if street use is more probable than not 3 speed trannys are not fun at 70mph. If the tranny whichever one is thrashed on alot failure will eventually occur with any of them.
I like my 4L60 level III from gearstar the low gear of the 4L60 is awesome along with the overdrive.
Old Mar 29, 2007 | 06:11 PM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
Re: th350 or 400?
Its not a daily driver, really a weekend bruiser, dont care much about od, but it would be nice. It's also carburated and its not going to be good on gas any which way, so......
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
89newfun
Sep 16, 2015 09:28 AM
FtrSpeedy
Sep 7, 2015 12:11 PM
