t-5 problems popping outta reverse
Old Mar 31, 2007 | 10:41 PM
sirx's Avatar
Just got the car, It shifts fine in all the gears but when I put it into reverse And slowly let out the clutch, it pops outta reverse, sometimes when it does this it seems to be getting stuck into 2 gears as it will not move. There is quite a bit of play in the shifter I dont know if buying a pro 5.0 will fix it or are there internal tranny issues. I'll be dropping in a 383 soon and I'm not sure if I'm going 6 speed yet or having the tranny built. If i go 6 speed dont wanna waste the cash on the shifter for the t5. Just wanna fix the problem and drive until the stroker is done.
The car is a 1991 RS with a 305 and T5 thanks for any help.
Old Apr 1, 2007 | 02:13 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: t-5 problems popping outta reverse
When that happens in the other gears it usually means the synchros are bad, but reverse isnt synchronized. I would bet on a chipped tooth or something similar on the reverse gear. There isnt much you can do to build up a T5 to make it strong enough, so just save up for the T56.
Andrew6.688
Dec 13, 2015 10:59 AM
PATRIOTIC1911
Sep 1, 2015 07:26 PM
Cacike
Aug 27, 2015 05:10 PM
Rakim_RS25TH
Aug 27, 2015 05:04 PM
hokis
Aug 9, 2015 03:57 PM
