4th gen T-5 questions
Old Apr 2, 2007 | 01:00 AM
boostedv6's Avatar
I want to do an auto to 5 speed swap but I am turboing my v6 right now so I doubt a third gen T-5 will last long in the car. My questions are: is the T-5 from a 4th gen any different/stronger than the third gen one? Also, is swapping that tranny into my car any different than swapping in a third gen T-5? Thanks
Old Apr 2, 2007 | 05:49 AM
Re: 4th gen T-5 questions
No.
Yes.
Old Apr 2, 2007 | 12:35 PM
boostedv6's Avatar
ok, so what is different about the swap? are they not the same lenth? shifter in a different position?
Old Apr 2, 2007 | 12:49 PM
Look at some pics on eBay or something.
One picture is worth a thousand words.
Old Apr 2, 2007 | 09:49 PM
voodoo7869's Avatar
Car: 91 formula converted to ws6 ta
Engine: 350 chevy
Transmission: 5spd
The only real diff is the t5 for a 90 and newer is a wc t-5 (higher torque load)
The NWC t-5 will hold about 270 lbs of torque where the wc t-5 will hold about 320 depending on which version you have. the wc is better. But I have used my t-5 wc for abot a year and it lived just fine behind my 377 pushing 450hp and about 375lb of torque. so you be the judge there are mods you can do to increase the torque capacity. Just make sure you get the correct case and input shaft for your application
Frozer!!!
Jan 19, 2024 04:55 PM
Casey Meyers
Mar 2, 2016 10:46 AM
redmaroz
Aug 16, 2015 11:40 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
