POP!
Old Apr 4, 2007 | 10:31 AM
Calaban007's Avatar
Car: 95 Z28/IROC-Z
Engine: LT1/L98
Transmission: 6 Speed/700R4
Axle/Gears: 3.42/2.77 Boo!
POP!
I've just begun to work on the IROC I bought. I did a tune up which made a world of difference, but I've taken it down the road a few times, no tags or insurance. Just to get a feel. Everytime I punch it from a stop or slow roll I get a really loud pop from under the rear. I'm wondering if it's the universal joint or maybe a transmission mount is bad. It cruises fine but if I get on it, POP! Just wondering what you guys think. Maybe it could be something else I don't know about. Thanks.
Old Apr 4, 2007 | 10:42 AM
rn2686's Avatar
Car: 92 Camaro RS
Engine: Secret
Transmission: Secret
Axle/Gears: Secret
Re: POP!
I had a 94 formula that did that. Turns out the front torque arm bolt completely fell out. The torque arm was slamming into the bottom of the car every time I would "get on it". I'd check that first, it's your cheapest fix ($0.50 bolt).
Old Apr 5, 2007 | 02:44 AM
Pat Hall's Avatar
Re: POP!
99.9% of the time, that noise is due to a broken trans mount. If that ends up being the problem with yours, do yourself a favor and buy an Energy Supension polyurethane mount. They're only about $22, and they're Wayyyy stronger than the pathetic GM rubber mount. You can also get their polyurethane torque arm mount while you're at it for another $15. It should only take about an hour to change out both, and your car will thank you for it!
RS Reaper
Oct 17, 2018 07:52 PM
Luigytico09
Oct 1, 2015 08:46 AM
aaron7
Sep 30, 2015 09:15 AM
RS Reaper
Sep 27, 2015 07:04 PM
Lmancha96
Sep 25, 2015 08:11 PM
