replaced rear end., and i broke it
Old Apr 4, 2007 | 09:13 PM
gottfuel's Avatar
Car: only GM,88 camaro, 91r/s camaro, 91
Engine: Clean oil, looks fresh, no leaks
Transmission: Bright Red, never burnt, no leaks
Axle/Gears: currently whining
yea so long story short, i had a whine in my rear end., that was throttle sensitive,. and i replaced it with a whole nother rear end., nothing new.,just one from a doner car., and every thing was going good,. and as i was driving it down to the auto zone for fluied,. it sounded like somthing mechanicaly went wrong like clanking and then like something dragging,. then started go go away., now it seems it right back where i started from it has a whine to it at hiway speeds then goes away when i let up off the throttle.,,.what is my problem ., could it be possible (and hear me out on this) that the chity shocks that are on there is causeing it to mess up,. someone putting to much pressure on the pinion., from bottoming out,. cause im sitting really low,. i was gonna replace the shocks but seemed i could not turn the fuggin nut loose with out the stud turnin as well,. anyway when i got home i put in a whole bottol of fluied., i could not believe it took the whole, i thought for sure, there was some fluied in there.,,. so what yall think ,.,. where did i do damage., or is this happining from my shocks??
Thanks in advance
Old Apr 5, 2007 | 10:16 AM
ziggy89's Avatar
Car: 91 Firebird Formula
Engine: 383
Transmission: built 700r4
Axle/Gears: 4.11, 9inch
Re: replaced rear end., and i broke it
i wouldnt have driven it with out the fluid in it thats probably why it started to whine again. It needs to be lubricated and from the sounds of it you didnt do it.
Old Apr 5, 2007 | 10:30 AM
It's not the shocks; believe that.
I'd be more inclined to think it has something to do with being run dry. Not to be mean or anything; but it's generally understood that it's a good idea to check the fluid level in junk parts you put in your car, if only just for the helluvit. Just a thought, for next time, you know.
The rear should hold about 2 bottles of fluid. I'd suggest putting another one in it. Although, it's probably too late now, it's already smoked. Probably every bearing, every gear, and the axles.
Old Apr 6, 2007 | 12:28 AM
gottfuel's Avatar
yeah thats for puting it lightly,. hey what can i say , i learn somthing new every day., but honestly i shoulda know thats just comon sence..lol..now ima have to find another rear end and do it all over again....................bottom line
Old Apr 6, 2007 | 12:43 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Yep, sad but true. That rear end is now probably in worse shape than your original one!
I wouldnt do more than run it across the garage with no oil in it, let alone drive downtown!
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
hectre13
Aug 26, 2015 08:17 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
BlackBoulder
Aug 11, 2015 11:15 PM
