Flare up on 2 to 3 shift
Old Apr 8, 2007 | 07:42 AM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
Tranny shifts fine on 1 to 2 (Hard) On the 2 to 3 shift under heavy throtle the tranny flares for just a second...Does not slip, or anything after that...It is worse with less TV Cable pressure.....So I run it as tight as I can, but when I floor it, it pulls the cable out, so I constantly readjust it...ANYWAY, what are the possible causes of 2 to 3 flare up???? I know the tranny is high milage, but am hoping to not rebuild it for awhile longer....Thanks for any ideas on this subject, Tom
Old Apr 8, 2007 | 08:15 AM
D BERRY's Avatar
Car: 89 Camaro RS
Engine: LO3
Axle/Gears: 273 pegleg
Re: Flare up on 2 to 3 shift
Don't know the answer to the question but have exactly the same problem, I'd call mine a lazy shift from second to third. For all I know it's designed in from the factory. Hope the fix is something simple like a shift kit or some sort of adjustment.
Dave B
Old Apr 8, 2007 | 08:30 AM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Ive already got a shift kit, and a corvette servo, It shifts great all other times 1 to 2, ans 3 to 4......I keep thinking there could be something sticking inside......There was no gunk in the pan when the fluid, and filter was changed, nor when the shift kit was put in.........I know I have a rebuild in the future, but not yet...I can drive it like this for a long time im sure, but I dont like it when im at the track, or in a hurry....lol....Thanks again, Tom
Old Apr 8, 2007 | 09:48 AM
92fbodyragtop's Avatar
Car: 1992 Firebird Convertible
Engine: 355
Transmission: 700-r4
if the tach is flaring between 2nd and 3rd, sorry to be the bearer of bad news but the 3-4 clutches are probably on their way out. Went through it on my 92. good news is it is a relatively cheap repair.
Old Apr 8, 2007 | 12:31 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Kinda knew that, but was hoping it was a sticking valve....Guess I can have just a minium done to it right now, or just drive like a normal person for awhile..(Damn that is no fun) It has been this way for over 20,000 miles now....Did you do just the clutchs, or did you do a complete rebuild????Thanks, Tom
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
darwinprice
17
Oct 11, 2015 11:51 PM
racereese
Oct 3, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
romcjr
Sep 17, 2015 05:18 PM
