pinion shaft removal
Car: 1989 Iroc rebuild
Engine: 355 carb'd
Transmission: 5spd
Axle/Gears: 3:08 pos for a while
on a Auburn limited slip.have the crossbolt out but the shaft is in pretty tight,searched thread and saw some sofakingdom thoughts,is there some tool to remove tension from the clutch pressure,??hammer it far enuf to get the c clips out,then after change hammer it back?
Engine: 355 carb'd
Transmission: 5spd
Re: pinion shaft removal
pin is out ,but how do you get the c clips off,since the clutches are in the way??even pushing in the axles,there is no clearance to get the c clips?my open rear was no problem,but didn't have the limited slip either
The clutches aren't in the way. You just push the axles in and the clips fall out. Same as an open diff.
As I probably told whoever asked that same question that you found the answer by searching, in order to take the bind off of the side gears, you need to take the tension off the clutches. It would have been best to do it before taking the pin out, so that the side gears would have been captivated in the right spot to make putting the pin back in easy. Oh well. Or, the REALLY best thing, would have been to drive the car in a STRAIGHT LINE for a bit before taking it apart. The clutches get that way from the last thing you did before taking apart, having been going around a turn.
dbrochard
Oct 3, 2015 12:43 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
