assembling a rear end
Old Apr 10, 2007 | 08:18 PM
BadIROCZ's Avatar
Car: 89 Iroc Z
Engine: Gen 1 350
Axle/Gears: Stock and shitty
where cna i find a nbook to acurately tell me how to assemble a rear end ? i need a few tools but can get them off the tool truck and alldata sucks
greg
Old Apr 10, 2007 | 11:17 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: assembling a rear end
If you don't have the proper tools, and there are a few special ones required, I would reccomend taking it to an experienced shop - at least to setup the gears properly. If you don't set the backlash properly, then you'll chew up a new set of gears in no time, and you'll hear them whining like crazy too.
The rest of it is actually pretty straight forward... just the reversal of disassembly. Just make sure you install new seals on the tubes and pinion, replace the bearings if required, and just pay attention to what you are doing during reassembly, and you'll be ok.
Old Apr 11, 2007 | 03:34 AM
ede's Avatar
ede
i have a older chilton and motor that both have a good how too section for drive lines.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
