3-4 clutch pack
Old Apr 11, 2007 | 11:41 PM
305blackbird's Avatar
Car: 1987 pontiac Trans Am
Engine: 1988 305 TPI
Axle/Gears: 2:73 ... I think
3-4 clutch pack
how hard is it to install a 3-4 clutch pack on a 700r-4 and do a rebuild or how much $ it would cost to get someone to do it 4 me
Old Apr 12, 2007 | 12:23 PM
Drac0nic's Avatar
Re: 3-4 clutch pack
So, you fried your 3-4 pack eh? I did a full rebuild of mine recently, it cost me ~400 to do it with a new converter, bigass cooler, all the small stuff and a basic rebuild kit. I messed up on the TV cable (TPI TV cable on a TBI motor) and burned the 3-4 pack a second time, costing me ~100 more after fluids and such (I ended up using ~4-5 gallon to flush the converter well) I have about another 75-100 in valve body mods as well (Transgo HD shift kit, 'vette servo boost valve 9C1 3-4 assembly and so on) to boot. The pics I took while I did it can be found here. Oh yeah, it's not 100% done (have a few more pics but not many)
Besides that I will add BLOW $30 ON A NEW TV CABLE. I got one from the JY that was stretched beyond adjustment (think it was there with a blown trans, imagine that) mine had 1/2 inch of stretch in it compared to the new one too so I'm wondering if it took my old trans out.
Old Apr 13, 2007 | 09:20 AM
mdricken's Avatar
Car: 92 Camaro
Engine: ZZ4 Crate Engine w/Hot Cam
Transmission: Rebuilt 700R4 with Transgo and MW 3
Axle/Gears: 3.73 Eaton Posi
Re: 3-4 clutch pack
It took me about two weeks to do start to finish. But I have a nice shop with a lift (very helpful).
It's not too hard. Just take your time and don't rush things and follow instructions. Get ATSE book for $10 - it is totally worth it for this job.
It cost me about $200 in clutches/bands, etc. and I put in a $500 3000 stall converter. I also got the TV bracket setup from bowtie overdrives. Man that thing works great. $100 but it is worth it in my opinion to not burn up your brand new tranny
If you have a shop rebuild it I think I was quoted a minimum of about $800, but most wanted more. And then you'd have to work with them to have them put in the beefier parts.
Old Apr 14, 2007 | 10:14 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
Re: 3-4 clutch pack
My friend fried his 3-4 clutch packs twice. He just ended up putting new trannys in instead of the rebuild process.
Old Apr 16, 2007 | 11:43 AM
sleeper383's Avatar
Car: 1984 Camaro Z28
Engine: 5.0L
Transmission: Heavy duty TH700R4 B&M shifter
Axle/Gears: BorgWarner 9 bolt Ratio 3.45
Re: 3-4 clutch pack
What about the Z-Pack clutch pack for 3-4, anyone of you installed these in your trans....,
Hare they realy strong or not.
Fanatic1074
Oct 3, 2022 05:57 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Zell1luk
Sep 29, 2015 10:36 AM
mfp189
Sep 27, 2015 09:25 AM
6998poncho
Sep 25, 2015 02:56 PM
