shft kit?transmision?u joint?whats wrong???
Car: 1985
Engine: lg4
Axle/Gears: ????????
i have recently bought an auto 1985 chevy camaro when you push it to the the floor from a stop or slow roll there is a loud thump ,it sound like it come from under the pasenger side near the motor and thre is a sound under you like a thump and the car vibrates the shift **** feels like it will fall through the floor and you will roll off without it.does any one have a suggestion or a simalar prob.thanx
Re: shft kit?transmision?u joint?whats wrong???
What's wrong? First thing to check, transmission mount, Probably broken and allowing trans to lift and " thump " on floor, very common in our cars. I replaced mine with poly mount, no more problem. Hope this helps.
Car: 91 rs
Engine: 305tbi
Axle/Gears: 3.27 9bolt
definately the trans mount, just fixed this problem. it cost like $7 from the auto parts store, they had it in stock, easy fix. hope this helps.
Car: 2000 BMW M5
trans mount. My friends 83 w/ T5 busted the mount while driving, and when you floored it it would go BOOOOM and shake the stick so bad you thought the car was coming apart.
Your transmission is a 700R4 auto unless someone changed it out to some older 3 spd. You don't know what engine is in there?
Car: 1991 Camaro RS
Transmission: 700 R4
I agree with the guys above. I had to change the trans mount in every third gen I have ever owned.
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
