Posi rear end?
Car: 1988 Firebird
Engine: 2.8 liters of fury.
Axle/Gears: Stock
Posi rear end?
Hey all, stupid question, but I have an 87 Formula and wanted to know if this car has a posi rear. Is there any way to tell by the vin or door jamb or something? I would just do a peel em but I don't think my neighbors would like that to much. Thanks, MAC
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Posi rear end?
Look at the pumpkin for a metal tag. If it's there it'll say it's a posi or not. So if it's grimy, bent, and old, then maybe you have the stock rear, and that's whats in there. If you have any inclination the rear end has been tinkered with in the last 20 years of that cars life, then you have no idea what's back there - unless you remove the cover, drain and refill the fluid (probably overdue anyway right?) and have a peek.
Car: 1990 RS
Engine: 305 TBI
Transmission: 4 SPD Auto
Re: Posi rear end?
Lift back end up on a jack , spin one wheel if other side spins in the same direction it is posi.If it spins in opposite direction it is single tire fire !
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
