Transmission Problems
Old Apr 19, 2007 | 09:51 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Axle/Gears: 02 WS6 Rear w/3:42
Well today on my way to work my transmission wouldn't shift. I had a 700R4 tranny that was rebuilt 3-4 years ago. I backed out of the driveway and when I put it in drive and got to around 10-15 mph. I was waiting for it to shift but the rpm's just kept climbing I pulled a u-turn then went back to my house. I didn't really get a chance to check it out since I was late for work. I just got home and wanted to know what the problem could be and what I should look for tommorow.
When I was coming back to my driveway I put the car in nuetral and revved it up just to make sure I wasn't in second gear or something. My car was fine on Tuesday. I put a new thermostat in yesterday but didn't drive it so this happened out of the blue. I put a new filter/fluid in about 3 months ago and adjusted the tv cable about 2 weeks ago. I will check the fluid tommorow just to be safe. I hope its an easy fix
Old Apr 20, 2007 | 09:59 AM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Re: Transmission Problems
I just warmed the car up and checked the fluid, it was good. I jacked the car up and checked the tranny just to make sure connections were nice and tight. everything looked good as far as I could tell.
Old Apr 25, 2007 | 05:41 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Got my replacement governor gear in the mail today. So I took the governor assembly out and it is infact the governor gear. Like half of it is gone Do I need to worry about the chunk missing? I don't see how be able to check around for it in such little space. Or do I just need to do a filter & fluid change and be done with it? And to get the gear off all I need to do is take that metal pin out and then I should be able to pull the gear off?
Old Apr 26, 2007 | 03:15 AM
Pro Built Automatics's Avatar
Do not be concerned with the pieces left behind, nothing will happen. Remove the pin, install new gear, drill through the gear with a .125" drill, install new pin, blow off everything with air, put some oil on the governor, install the cover with a new seal (no sealer) by tapping on the outside of the cover (not in the middle), your done.
Old Apr 26, 2007 | 03:11 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Just what I needed I got the new one in and all is good now
jhawkeye
May 25, 2022 06:33 PM
AussiePr0nCar
Mar 6, 2020 04:04 PM
Cleotiz
Jan 6, 2018 08:56 PM
BlackphantomZ28
Apr 24, 2016 08:14 AM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
