HELP! t-5 swap
Old Apr 21, 2007 | 11:02 PM
johnnyboy's Avatar
Car: '82 formula clone, 95 saab 900se
Engine: 350 vortec'd tbi, 2.0L turbo
Transmission: 700r4, 5 spd
Axle/Gears: 10 bolt 2.77 open
HELP! t-5 swap
i've got awc t5 from an 89 iroc 305 tpi that i was going to sell but it would just be more fun to have it in my car instead of the 700r4. but i don't know all of what i'm going to need for the swap, i've searched but i can't find any good info. i know i'm gonna need the bellhousing, and the pedals and flywheel and pressure plate and clutch and all that good stuff but what other stuff is there? the crossmember is different from the auto to the manual trans right? thanks for your help
Old Apr 21, 2007 | 11:08 PM
fire350tpi's Avatar
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
Re: HELP! t-5 swap
i believe you have it covered, but dont forget the hydraulic setup ( master/slave cyl)
and ull have to drill/cut out a hole for the master cylinder near the pedals
Old Apr 22, 2007 | 08:15 PM
83Camarofvr's Avatar
Car: 83 Camaro duh
Engine: 355
Re: HELP! t-5 swap
I swapped a 700r4 for a T-5 in my 83. The crossmember and driveshaft were the same.
Old Apr 22, 2007 | 08:51 PM
johnnyboy's Avatar
Re: HELP! t-5 swap
cool, i was hoping i wouldn't have to change the crossmember
Old Apr 22, 2007 | 10:22 PM
89_ho_rs's Avatar
Car: 1989 RS Camaro
Engine: 350 Carb(soon a 400)
Transmission: 5-Speed/th350
Axle/Gears: 10 bolt 3.73
the hardest part of doing it is making sure you cut enough for the shifter but not too much. and also the hole for the clutch master cylender. other than that it is easy.
midge54
Sep 2, 2015 06:27 PM
Cacike
Aug 27, 2015 05:10 PM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
