TV modulator upshift/downshift spring
Old Apr 23, 2007 | 08:13 PM
Drac0nic's Avatar
I was just curious as to what effects reversing the TV modulator upshift and downshift valve springs would have. I have 1-3, and 4 but if I give it any gas hardly it down shifts back into third. I think I may have reversed these two springs during the rebuild (#s 302 and 304 in the ATSG book) What are the right colors for them if I pull the VB to check. Also, any other thoughts on what may be causing this issue?
Old Apr 24, 2007 | 05:24 PM
Pro Built Automatics's Avatar
Re: TV modulator upshift/downshift spring
Leave the TV modulator upshift and downshift valve springs alone. The TV plunger sleeve 4-3 downshift passages are what controls the 4-3 downshift as to how easy or hard the 4-3 downshifts are obtained. You can block these passages with two small Allen screws and a dremel, $.34 cents for two. This will eliminate the 4-3 downshift at higher speeds (apx. 65-75mph), and at lower speeds you still will have the 4-3 downshift, depending on the rear end gear ratio. If you have access to a few 700R4 valve bodies, then you could locate one that will make it harder to get a 4-3 downshift, but not eliminate it all together.
Old Apr 25, 2007 | 04:14 PM
Drac0nic's Avatar
I have the no 9C1 3-4 assembly in my 700, so I'm good to go there. My problem is that I have a 4th gear that drops into it then downshifts out afterwards in OD. I took it apart and found out the 4th apply piston was backwards last night, but still no dice on it. I was just wondering if I re-installed the TV up and downshift springs into the wrong passages if it would effect it by not having a 4th gear.
Old Apr 25, 2007 | 05:15 PM
The upshift and downshift valves cannot be mixed up, the same for the springs, they are different sizes. The bigger valve has the light spring, and the smaller one a heavy spring. You could recheck all of your work, but I would call TransGo at 626 4437451 ask for Dave, he should be able to help you out here.
pjsparts
Oct 29, 2025 06:39 PM
87v6Bird
Jul 1, 2018 04:12 PM
djmarch
May 8, 2016 11:32 AM
RedLeader289
Sep 23, 2015 06:50 AM
sandman92084
Sep 12, 2015 10:27 PM
