oil pump, torque converter how to test?
Old Apr 27, 2007 | 02:15 PM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
1986 trans am 305 tpi 5.0 v8 automatic transmission
My car usually has a strange idle up n down up n down then settles once it warms up.
and recently wants to die unless i give it gas when i shift into reverse. Once i press on the gs beforre it dies it goes backwards kinda sluggish but it goes and doesnt die and allows me to shift into drive.
ive read up this might be my torque converter. is there a way to test or how much do you tihnk it will cost to replace?
also read soemthing about the oil pump might play a part.
any way to test any of this? or what do you guys think i should do?
i will check the transmission fluid level. it looks fresh n light red. but i laso noticed a small leak. so maybe the torque converter doesnt have enough fluid flowing through it??? maybe???
anyone want to lend some tips?
Old Apr 27, 2007 | 02:52 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: oil pump, torque converter how to test?
Neither of those is your problem. Your transmission would have to be hemorrhaging for a leak to be a problem, and if your car can go forward ok, then there's nothing wrong with the torque converter. If you had a problem with the oil pump you'd know it too as the engine ate itself.
Old Apr 27, 2007 | 03:02 PM
Bobby_80s's Avatar
Axle/Gears: no idea
ok so back to the tpi/ engine threads?
any ideas abou my reverse problem?
Old Apr 27, 2007 | 07:40 PM
Hellraiser's Avatar
Bobby, i think what youre experiencing is more likely engine related... I'd look towards the Idle Air Control motor in particular, from your description of the problem! : )
Old Apr 27, 2007 | 08:36 PM
Bobby_80s's Avatar
Axle/Gears: no idea
IAC is bran new. most liekly a stupid vacuum leak that i cant seem to find or MAF sensor/relay thanks guys. i did soem reading and wanted to see what you thought thanks
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
jklein337
Sep 19, 2018 06:23 PM
toronto formula
Nov 10, 2015 06:17 AM
Navy8125
Aug 21, 2015 09:32 AM
gwade12
Aug 8, 2015 08:17 AM
