NEED help with 700r4
Old Apr 28, 2007 | 10:44 AM
[R]ogue's Avatar
Car: 84 bird
the 3/4 apply servo is stuck in the case. this isn't my first rodeo... so i'm doing it as I normally would. i took the snap ring off the cover, the cover will not come out of the bore. i even LIGHTLY tapped on the servo apply pin from inside the case and still no progress! does this mean that my case is trashed? TIA
Old Apr 28, 2007 | 07:28 PM
Pro Built Automatics's Avatar
Re: NEED help with 700r4
You must take out the blue seal in the cover first, or it will never come out! Pull down on the seal using a scribe, cut it, and grab one end with a pair of pliers, pull down until it is out completely, now pull the cover off.
Old Apr 29, 2007 | 04:31 PM
[R]ogue's Avatar
Car: 84 bird
that worked! thanks dude
Old Nov 15, 2013 | 11:33 AM
calgaryz28/83's Avatar
Hello, i am trying to figure out why my trans crossmember will not bolt up to my frame rails, trans seems to be long and not sure what to do. Thinking of drilling new holes in the crossmember, Any advice out there
Old Dec 15, 2013 | 10:27 AM
TexasT's Avatar
Car: K2500 Suburban
Engine: big one
Transmission: overdrive
If the cross member came out of there it should be able to go back in. Have you looked over other parts of your install to see what is keeping the holes from lining up? You might have worn or shot motor mounts that when you removed the cross member the engine moved.
I've used a large punch(11" or so) or two as an alignment tool. By putting it into the hole at an angle and prying the cross member you can get the second bolt started then get the other side started. This will allow the other two bolts to get started. Then you can snug it all down .
Pix are worth a thousand words. You might snap and post some where we can see what might be holding you back.
And you might start a new thread or get a mod to move this to a new thread so you get more exposure. Good luck!
Old Dec 16, 2013 | 04:32 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
https://www.thirdgen.org/forums/tech...formation.html
Some idea of the year / trans might help in your own new thread about your problem
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
