shifter on a t56
Old Jan 27, 2011 | 04:01 PM
92rs85berlintta's Avatar
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
shifter on a t56
Does anyone know if a gto t56 shifter will bolt to a camaro ls1 t56??
Old Jan 27, 2011 | 08:08 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: shifter on a t56
if you change the offset shifter block (one roll-pin holds it in place) to the GTO O.S.B., yes.
Old Jan 27, 2011 | 08:59 PM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
OK thanks, I asked because I have a ls1 t56 in my lt1 powered 92 camaro and the shifter sits too far back. I was looking at b&m gto shifters and noticed an adapter of some sort that moved it even farther back. My idea was to buy the short throw and just flip the adapter the other way to get it back to where it should be.
Old Dec 15, 2013 | 12:31 PM
ohenryd46's Avatar
what if I have a ls6/t56 in my 1991 Camaro rs, what will I have to do to get the shifter in the consol
Old Dec 15, 2013 | 06:23 PM
Pocket's Avatar
Car: 91 Trans Am
Use a manual shift plate. Should fit fine unless you're using an oddball shifter
Firebirds can use auto or manual shift plates because of the boot. Camaros use a plastic slider
Old Dec 16, 2013 | 06:09 PM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
If you have a standard small block with ls tranny adapter you will need to clearance the stock metal trim plate a small amount, it's the part that holds the boot on. Next to get the shifter in the right spot you can run a mustang t56 shifter stick. This will move it forward about 1.5-2 inches.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
meeklay812
Oct 1, 2015 03:46 PM
