Weird vibrations
Old Apr 30, 2007 | 07:36 PM
transamice's Avatar
Car: 87 GTA t-top
Engine: L98 350 w/RMT
Axle/Gears: 9 bolt BW 3.45
Weird vibrations
I've swapped out my TPI 305 for a 350, changed to 350 prom, injectors and knock sensor. (1987 GTA 350 TPI auto)
I changed the intake last summer as well to HSR.
The problem I have is a rumble when I accelerate and I just cant figure out whats the cause. This was a minor problem after installing the 350 but worse now.
Feels like Im loosing power when throttled.
Engine/ trans mounts are solid, driveshaft is good, could a bad harmonic balancer cause this problem?
Im just tired of this rumble and its only getting worse and Ive run out of ideas to the cause.
Any advise would be appreciated.
Old May 3, 2007 | 08:43 PM
transamice's Avatar
Car: 87 GTA t-top
Re: Weird vibrations
I got the car in the air noticed most the vibration coming from the transmission and engine.
At 2000 rpm the car shakes and rumbles, runs ok at 1500rpm and higer than 2600rpm, could this be my flexplate or anything else come to mind?
69GTOby
Apr 18, 2016 02:34 PM
sac92transam
Oct 7, 2015 02:31 PM
roysatikas
Sep 22, 2015 08:15 PM
BWilcox
Sep 20, 2015 12:19 PM
InfinityShade
Sep 18, 2015 08:32 PM
