t56 swap
Old May 2, 2007 | 11:12 AM
withoutanycause's Avatar
Car: 87 iroc-z28
Transmission: th350
t56 swap
i found a decently cheap t56, but its from an s-10. i was wondering if there is a significant difference, if any, from a t56 from a 4th gen. If there is, is it close to the same difficulty as doing this swap with a 4th gen. t56?
thanks in advance for the help.
Old May 3, 2007 | 11:16 AM
91L98Z28's Avatar
Car: Z28
Re: t56 swap
s10 never had t56, its either NOT a t56 or the owner swapped a t56 into it.
I suspect the former (it's not actually a t56) unless it's one of those v8-swapped s10's then who knows.
Old May 6, 2007 | 10:38 PM
Car: 87 iroc-z28
Transmission: th350
Re: t56 swap
i was thinking i had never heard of a t56 in an s10. the guy said that its from a wrecked s10 with a 383. not sure if this helps any.
Old May 7, 2007 | 01:57 PM
StreetRoc85 350's Avatar
Car: 88 IROC
Transmission: Pro 5.0 shifted T56
Axle/Gears: 10 bolt 3.73 posi
Re: t56 swap
if its bolted up to a SBC then its an F-bod tranny. i dont think any other GM car came with a 6sp and a V8. the corvette uses a different setup.
Old May 7, 2007 | 05:55 PM
91L98Z28's Avatar
Car: Z28
Re: t56 swap
if you were really thinking obscurely, it could be a corvette ZF6.
Old May 7, 2007 | 06:41 PM
Car: 88 IROC
Re: t56 swap
was that a c-4?
Old May 8, 2007 | 07:47 PM
Car: 87 iroc-z28
Transmission: th350
Re: t56 swap
if it is from a corvette, would it be about the same difficulty as using a t-56 from a camaro?
AussiePr0nCar
Mar 6, 2020 04:04 PM
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
19irocz85
Aug 30, 2015 10:03 PM
19irocz85
Aug 26, 2015 07:54 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
