700r4 to th-350 of 400
Old May 3, 2007 | 11:28 AM
Dainius's Avatar
Car: 1990 RS
Engine: 305 carb
Transmission: 700r4 with transgo shift kit
Axle/Gears: ?? not sure yet just got the car
what would i need to do to swap my 700r4 to this turbo 350?? I know i will have to get either a longer or shorter tailshaft? what else would i need to do?? converter and would it bolt up? also what about the crossmember? any advice would be great
Old May 3, 2007 | 01:11 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
Re: 700r4 to th-350 of 400
th350 trannies came in thrree different lengths for 2 wheel drive 1969 to 1986
for the 700r4 you need a th350 with the 9" tail
find them in some wagons and in all the trucks from 73-up
then you dont need to change driveshaft
some of the 70s wagons are the 12" tail, but not so common, so watch out
a th400 will take the 700r4 shaft but you gotta convert to the 32 spline 400 slip yoke
some 400 used a bolted on yoke, mainly in trucks and vans
but you can use a slip on one just the same on them, no difference other than a threaded hole in the end of the tailshaft for the bolted on ones
Old May 3, 2007 | 06:10 PM
Dainius's Avatar
Car: 1990 RS
Engine: 305 carb
thats helps alot!! thank you very much.... my local parts store has a th-350 streetfighter from tci that a customer ordered for 1800 bucks.. he never came and got it so he offered it to me for 450! im thinking yea.. trading out my 700r4 and this 350 is brand new lol... so i may have to find a diff tail shaft depending on which one he has... other than that is everything else pretty much a straight shot? like the trans lines and kickdown cable and crossmember mount?
Old May 3, 2007 | 06:14 PM
Blackroc86's Avatar
Car: 1986 Iroc
Engine: 454 Demon 850DP
Transmission: TH350, 3500 stall
You will also have to get the B&M or Hurst kit to attach the torque arm to the TH350 or TH400.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
6998poncho
Sep 25, 2015 02:56 PM
