83-86 t5
Old May 7, 2007 | 09:28 AM
theorio1025's Avatar
Car: 1984 Camaro Z28
Engine: 350 from an elcamino
Transmission: stock t-5
Axle/Gears: 10 bolt 3.73 limited slip
83-86 t5
will the 83-86 f-body t5 bolt up to an 87 up engine, with the one piece rear main seal?
Old May 7, 2007 | 12:40 PM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Re: 83-86 t5
I'm sure it would if you use the '87 up flywheel. Not sure if the 2 piece RMS flywheel is different...
I do know, depending on the year of the trans, you might have no provision for the hydralic clutch on the bellhousing. Which means use the '87 up bellhousing or install a mechanical z bar linkage (hard to find nowadays). Other than that, yep it'll fit.
Old May 7, 2007 | 01:16 PM
z28freak84's Avatar
Car: 1985 IROC-Z Silver
Engine: Vortec 5.7L
Transmission: WC-T5
Axle/Gears: 3.23 disc brake 10 bolt
Re: 83-86 t5
83-87 T5=NON world class, 88-92= World Class.
83-86 Flywheels=Pre 87 blocks and 87-92 flywheels with 87&up blocks.
82 and 83 Stick Cars had Cable clutches and 84 & up had hydraulic.
82 was a 4 speed not a 5 speed.
There's your differences and compatibility issues. I think thats it.
Old May 7, 2007 | 02:46 PM
Re: 83-86 t5
my car is a t5. it was converted. the engine and tranny in the car match now, and theyre a pre-87. i know that the newer trannys are world class. if it is a t5 would it be a hydraulic clutch?
Old May 8, 2007 | 10:07 AM
Confuzed1's Avatar
Car: 83Z28 HO
Re: 83-86 t5
So your car was converted to a T-5 along with a pre-87 engine. Only you can tell us what type of clutch linkage it has - Hydraulic or mechanical. If it is a 83 model, it will have a mechanical linkage. '84 to '87 will most likely have a hydraulic clutch linkage.
crossrush
Apr 1, 2014 08:27 PM
V8ReiMeR88MaRo
Oct 21, 2013 09:55 PM
soarestransam
Jun 12, 2012 11:51 AM
305ho
Interior Parts Wanted
Jul 23, 2010 09:00 AM
John in RI
Jul 1, 2009 10:22 AM
