Console shifter loose car stays in park
Old May 7, 2007 | 08:09 PM
mbrownone's Avatar
Car: 3rd Gen Trans Am
Sorry for the lengthy description, but I'll try and tell you exactly what happened. Thanks for reading. Well, I got back into my car in a parking lot and started it. Tried to put it in gear (auto trans), and the shifter is just as loose as can be. The car will stay in park, but the shifter slides through PRND12 without any resistance. I thought a cable was broken or something. However, the tow driver came and reached under the car, grabbed the cable (or...???) and came out with a small rubber grommet that was decayed and said this was the problem. He reached under the car again and asked me to shift into Drive (which it did with him holding something underneath the car). He told me to go to PepBoys and it would be cheaper to just replace the grommet myself rather than take it anywhere. Sounds simple enough. But here is my problem.....
Drove to PepBoys and they don't have the part I need but referred me to a Pontiac dealer. All dealers are closed now and I rented a car. Is anyone familiar with the shifter problem Im having here? Seems like other cars have similar functionality and is straight forward to fix, but I havent run into this before. I would rather fix this myself as Im told it can be done without much effort. Very much appreciate any suggestions/comments/instruction with this. Let me know if you need more description or have questions.
Currently the car is parked in Drive gear since I didnt know where to grab under the car to shift out of it, and I thought PepBoys would be able to assist. I leave for MN tomorrow morning but will check my email while im away. Would like to try and fix when i get back. Its a clean car, but im sure that any rubber piece would get brittle after almost 25 years
Thanks again. Mike
1984 Trans Am
L69 305 auto
53K miles original
Old May 7, 2007 | 08:19 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Console shifter loose car stays in park
It's not the grommet, you've got a broken shift cable.
Old May 7, 2007 | 08:33 PM
Gramps's Avatar
Car: 87 Camaro IROC
i cant see how a rubber grommet would make prevent it from shifting, espically since the grommet doesnt actually do anything except protect parts from the elements.
get underneith your car and take a closer look. on the drivers side of the trans there will be a little arm poking out of the side of the case, thats where you select your gears. the cable should be attached to that. you can even move that little arm with your fingers to put it back into park. whats happened is your cable has snapped inside the rubber grommet, pull it back and youll see for yourself.
Old May 7, 2007 | 09:24 PM
mbrownone's Avatar
Thanks. I couldn't figure why a grommet had anything to do with it either, but thought i would ask. My car hasn't needed any work near the trans before, so I never paid much attn that area when underneath in the past.
Is a shift cable replacement a difficult job? I have plenty of tools and not afraid to try myself. But it's my primary driver at the moment so i really dont want to screw it up. I'll do some searches here on 3rd gen also.
"Ask twice (....or more), and fix once" is my motto....
Old May 7, 2007 | 09:34 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It's not difficult... if you know what you're feeling around for you can even do it just by reaching under the car while it's on the ground without even jacking it up. For the first time though it's a lot easier to jack it up so you can see what you're doing.
Old May 12, 2007 | 12:20 PM
mbrownone's Avatar
fixed it, thanks again
Ghettobird52
Jul 5, 2024 11:18 PM
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
NBrehm
Aug 25, 2015 11:49 PM
