Whats wrong with my transmission?
Old May 10, 2007 | 09:46 AM
88camarojake6's Avatar
Car: 88 Camaro (interior restoration)
Engine: 350 TBI
Axle/Gears: 3.08 (stock)
My transmission has leaked about a quart of fluid a couple of times now. I cant figure out where the leak is coming from, I think that the fluid might be coming from the overflow tube on the top of the transmission because the whole side is wet with fluid. I have not been driving it hard, and I wonder if the transmission is slipping. It also will only go 30 mph in first gear. It is a 700R4. Thanks for the help
Old May 11, 2007 | 05:42 PM
Nickofcourse's Avatar
Re: Whats wrong with my transmission?
did u overfill the transmission? maybe the filter is clogged and making it overheat wich boils the fluid out of the tube? make sure you check the level of fluid regularly since it is leaking so bad.
Old May 12, 2007 | 05:12 PM
Engine: 350 TBI
It has done this twice now, i refilled it with fluid the first time, to the right amount. That could be possible that the filter is clogged or maybe a fluid line inside the transmission. Thanks for the help.
GTAman
Jul 3, 2024 07:29 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
Dyno Don
Jan 24, 2016 08:24 AM
angel2794
Sep 8, 2015 06:22 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
