T56 questions!!!! plz help
Car: 1986 Chevy Camaro Heritage edition
Engine: V6 2.8 sadly...
Transmission: 5 Speed Manual
Axle/Gears: I have 10 bolt and i think 3:9's
how hard is it to bolt up a t56 6 speed to a high output 350? is there any special clutch or bellhousing that i need or will it bolt up? also will my original drive shaft work? the original engine is a v6 173 with a GM 77mm stock transmission. its an 86 camaro.
thanks
jake
thanks
jake
Received 1,697 Likes
Re: T56 questions!!!! plz help
This gets asked so many times it's not even funny.
Do a search on this board. Then go to the FAQ board and read the one about "questions you didn't even know you needed to ask about the T-56 swap" or some such.
If you can't find the answers you need from those 2 things, then you should consider a different hobby.
k thanks
1992 Trans Am
08-08-2015 08:16 PM
