Crossmember help
Old May 11, 2007 | 10:58 AM
xyzman's Avatar
Crossmember help
I have a 82 Z which has a 355 mounted to a turbo 350, what i would like to know is when I install a 700r4 will my stock crossmenber work or will I need a new one, the 700r4 looks a little longer than the 350, also will my stock shifter work with the 700r4, I do have the proper plate for the shifter. thanks Len
Old May 14, 2007 | 02:55 PM
cyko83's Avatar
Car: 83 trans am
Engine: 5.7 V8
Transmission: 700R
Re: Crossmember help
the crossmember for the 700r and the 350 turbo is differnet and so is the shifter. the 350 trans goes from D,2,1 but the 700r goes from d-with a circule around it then a D,2,1. the reason for that is that the 350 doesn't have an over drive but the 700r does. if u want i can give u my shifting counsal cuz i'm putting an t-5 in and throughing away my 700r trans and setup
Old May 14, 2007 | 04:58 PM
xyzman's Avatar
HI, THANKS FOR THE OFFER I ALREADY HAVE A SHIFTER COUNCIL FOR THE 700R4 BUT IT IS RATHER BEAT UP, IF YOU ARE INTERESTED IN SELLING THE CROSSMEMBER FOR THR 700R4 PLEASE LET ME KNOW AND YOU CAN INCLUDE THE SHIFTER COUNSOL WITH THE CROSSMEMBER, I NEED THEM BADLY!!!!!!! THANKS A MILLION, LEN PS DO YOU HAVE THE ROUND PLASTIC COVER FOR THE SPEEDO THAT HOLDS THE PLASTIC SPEEDO GEAR IN THE TRANS NEED ALSO, THANKS AGAIN
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
kammi10
Nov 9, 2015 08:28 PM
tmork454
Sep 29, 2015 06:33 PM
TOMcat GTA
Sep 15, 2015 09:31 AM
luvofjah
Sep 10, 2015 10:41 AM
